SS-V: 5030 Reactions at the Ends of Axially Loaded Plastic Bar
Test No. NVL04 Find reactions at the fixed ends and maximum displacement of a bar axially loaded beyond plasticity.
Definition
Bar dimensions are 10 x 10 x 200 mm. Distance between loaded point and left end A=50 mm. Strain-stress curve of the bar material is defined by the power law:(1)
σ=Kεnσ=Kεn
Where,
KK
Strength coefficient
nn
Must be in the range [0,1]
nn =0
Material is perfectly plastic.
nn =1
Material is elastic.
The material properties are:
Properties
Value
KK
530 MPa
nn
0.26
Poisson's Ratio
0
Figure 2. Corresponded strain-stress curve
The study was performed for the following load F values: 30000 N, 47000 N, 55000 N, and 60000 N. These loads cover the full range of elastic-plastic response of the bar.
Reference Solution
One-dimensional analytical reference solution is described here.
The length of the bar does not change under the load.(2)
A0ε1dx  LA0ε2dx = 0A0ε1dx  LA0ε2dx = 0
or,(3)
A0nN/(K*A)dx  LA0n(FN)/(K*A)dx = 0A0nN/(K*A)dx  LA0n(FN)/(K*A)dx = 0
Where,
ε1ε1
Tensile strain at the left span of the bar.
ε2ε2
Compressive strain at the right span of the bar,
NN
Reaction force at left end of the bar.
R=FNR=FN
Reaction force at the right end of the bar.
AA
Bar cross-section area
From this equation you can find the reaction at the left end of the bar.(4)
N = F/(1+(a/b)n)N = F/(1+(a/b)n)
and R = FNR = FN at the right end.
Results
Bar was modeled as a 3D solid with immovable ends. Axial force F could not be applied precisely at the solid bar axis, so four line spots were created at the bar sides and total load F was uniformly distributed over the spots (Figure 3).
Figure 3.
The following table summarizes the reaction force results.
Force F [N] SOL Reference, Reaction [N] SimSolid, Reaction [N] % Difference
30000 17128 18151 5.97%
47000 26834 27146 1.16%
55000 31401 31788 1.23%
60000 34256 34591 0.98%
Typical von Mises stress distributions are shown in Figure 4 and Figure 5. The distribution has high gradients at load application lines; yet the reactions values correlate to the 1D solution because the reactions are applied far from the active force.
Figure 4. von Mises stress distribution at load F=30000 N
Figure 5. von Mises stress distribution at load F=60000 N
